Forums >> Revit Building >> Technical Support >> View Specific Parameters
Fri, Sep 21, 2007 at 5:11:17 PM | View Specific Parameters
HCSCHULDT502
A have a large floor plan that needs to be broken up into multiple sheets in order to fit on the page.  I also have the same floor plan at a smaller scale that shows where all of the match lines are, and what each view is showing.  On the smaller scale drawing I would like to turn off lables such as, "up/dn" labels on stairs, "ref." lable on a refridgerator, "dw" label on the dishwasher, etc.  Although I would still like these labels to show up on the larger scale drawings.  Is there a way to add a visibility parameter to a label within a family that is view specific?  I realize that I can control the visibility by hiding it at coarse vs medium detail level, but i'd like to have both plans set on medium detail level.  Or is there a way to add a parameter that will "hide at scales coarser than" similar to a section or something?  Thanks in advance for your help.
Mon, Sep 24, 2007 at 1:44:55 PM | View Specific Parameters
laurabh
As far as the stairs are concerned - the up/down text can be turned on/off through Visibility/Graphics overrides.  I'm not sure about the dishwasher though - unless you changed the label in the family to only show up in Fine Detail level and changed the detail level of your views accordingly.
Title Block Specific Parameters
Mon, Jun 20, 2011 at 7:15:37 AM
view-specific resizing?
Thu, Aug 23, 2007 at 8:13:13 PM
View Specific Level Heads
Tue, Aug 21, 2007 at 6:40:14 PM
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
manually associate section mark to a specific view
Fri, Apr 3, 2009 at 1:11:54 PM
Page generation time: 0.7051
