Forums >> Revit Building >> Technical Support >> Structural elements are disjoined
Tue, Feb 8, 2005 at 1:17:40 AM | Structural elements are disjoined
Arquitrad
Hi everybody! I don\'t know how to join the structural beams with the structural columns. I don\'t know if it can be done or if the structural elements are just representation and never actually meet. Thank you I purged the rvt file, but I still get this size. Is this normal? I guess it's the same thing on the post http://www.revitcity.com/forums.php?action=viewthread&thread_id=742 Post edited on 2005-02-08 01:43:20
Tue, Feb 8, 2005 at 5:17:37 PM | RE: Structural elements are disjoined
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The structural elements will never actually meet and do this due to the fact there would most likely be a plate that holds everything together. I suggest changing the beams to a different family category, say generic models, so they lose there structural rules and you have a little better control. HTH.
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:34 AM
Replacing Structural Elements in Arch Model with Revit Structure elements
Sun, Dec 4, 2011 at 4:06:34 AM
crash when edit structural elements Revit 2015
Tue, Nov 18, 2014 at 12:24:45 PM
IMPORT 3d Wireframe and populate in Revit with structural elements
Fri, Mar 3, 2006 at 9:53:38 AM
Discipline - structural
Mon, Jun 12, 2017 at 2:38:52 PM
Page generation time: 0.4313
