Forums >> Revit Building >> Technical Support >> Dimension Leader
Fri, Sep 21, 2007 at 2:50:00 PM | Dimension Leader
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
Is there a way to change Revit 2008's default arc dimension leader.  I would prefer to create one with straight lines and elbows. Thanks.
Sat, Sep 22, 2007 at 9:49:22 AM | Dimension Leader
justinblack
You can either click on your text after you've typed it, then choose one of the leaders in the option bar. Or you can click on the text > properties > uncheck "arc leaders".
HTH
JB
Mon, Sep 24, 2007 at 12:24:31 PM | Dimension Leader
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
Yeah, I can get that to work with the text just fine, but not with dimension strings.  If I drag the number so that a leader appears its always an arc leader.  In order to be consistent w/ out text leaders (which have elbows), I would like to make the dimension string leaders the same.  Thanks
Mon, Sep 24, 2007 at 12:32:09 PM | Dimension Leader
justinblack
Sorry, my bad. I mis-understood you.
As far as I know I don't believe you can alter the arc when you drag the text.
JB
Revit Dimension Straight Leader Line with Controllable Node at Elbow
Thu, Jul 12, 2018 at 12:32:47 PM
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:40 PM
Adding Snaps to Leader Lines
Thu, May 29, 2014 at 7:34:34 AM
Leader Question
Thu, Jun 16, 2016 at 12:24:28 PM
Positioning the leader on a tag.
Thu, Aug 6, 2015 at 12:16:39 PM
Page generation time: 0.1126
