13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> cant rotate fill patterns
hey... I have imported couple hatch patterns from cad...when i did i only had option to change scale...now i need to play with their orientation but it seems that when i go to edit that imported pattern does not have option to rotate (like in simple patterns); I tried switching it to orient it to object but hatch still wont rotate...?
Check out the difference between 2d and 3d hatches.
19 Posts No Rating |
Hey Lucas, did you ever get a real answer to this? If so, please share! I can't figure it out wither.
The real answer .... Model hatches (3d) can be rotated - 2D (drafting) hatches can not. Look it up in your H E L P ! Rotating a Model Pattern
So if Revit won't import my hatch pattern as a Model Hatch,(It actually refuses to do it) I'm just Out of luck on that pattern?
iF YOU HAVE A 2d HATCH PATTERN, ALL YOU HAVE TO DO IS EDIT IT AND ADD 1 LINE OF TEXT. ;%TYPE=MODEL SECOND LINE OF TEXT IN THE FILE. Sorry for the caps
Edited on: Mon, Nov 17, 2008 at 4:42:55 PM
Got it. Awesome, thanks!
4 Posts No Rating |
RE: adding the line %TYPE=MODEL. Where is this added? I opened a .pat file and added another line at the bottom, but this didn't work. What am I missing?
4 Posts No Rating |
Never mind... left out the semicolon. Does work.
Rotate Model Fill Patterns [ 1 2 ] |
Sat, Nov 28, 2009 at 5:21:54 PM
15
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
A few questions |
Tue, Jun 30, 2009 at 11:25:53 AM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
