Forums >> General Discussion >> Wishlist >> About Material Tag
Fri, Sep 21, 2007 at 1:03:29 PM | About Material Tag
UTG
Hi all,
 I want to request redevelop a Material Tag feature. It work better on Elevation and Section view only.
If we put the date in identity material and used paint feature on object.
But it cannot used in plan view. When i uesd it show deferance with elevation. It will showing default data.
I would like somebody help to look this feature.
 Thanks,
I don't like to used Tag by element. Because if i have many material i must to have many object same
Yuthana subpaya-agin
Mon, Sep 24, 2007 at 9:15:46 AM | About Material Tag
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you used the Paint feature to "paint" a material in elevation, then the material is only to the surface of the object. You will need to define the material to the family (i.e. wall, floor, ceiling.....) in order to use the Material tag in all views.
Hope this helps.
Tue, Sep 25, 2007 at 12:31:27 AM | About Material Tag
UTG
Hi JAMESHGRIMES
Thanks. Yes that way, Tag will work when we put the data in wall family. If i have alot finishing wall. I will have alot wall family too. If Tag material can work with paint feature. It will make very easy to my work. Smile
How the way to do 1 wall family can put many material with work with tag material on plan. On elevation it can do ? why plan can not ?
Thanks,
Material tag and doors
Mon, May 29, 2006 at 5:04:07 PM
material tag
Tue, Jun 9, 2015 at 8:49:15 AM
no material tag in metric library
Wed, Aug 24, 2016 at 2:02:51 PM
material tag schedule problem
Sat, Mar 25, 2017 at 7:50:36 AM
Can't add shared parameter to material tag?
Mon, Jan 21, 2008 at 5:58:33 PM
Page generation time: 0.9679
