19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Rendering Plans and/or Elevations
6 Posts No Rating |
Is there anyway to render elevations and/or plans?
and
what is the best way to export elevations and plans, rendered or unrendered
----------------------------------- Matty B |
You cannot render a plan or elevation as such...
You can however create a 3D view, use view-->Orient-->To other view, then select the plan or elevation you wish to render. This will automatically create scope boxes to the extents of your view.
Now its just a matter of doing a raytrace...
Then use the export image to save the file out. A common technique is to then load it back in and place on a sheet then place the floor plan or elevation over the top to get the linework and notes to show. You will need to adjust the size of the image to match the plan/elevation by eye.
HTH.
Rendering site plans and elevations to scale, is this possible? |
Wed, Dec 5, 2012 at 10:33:34 PM
Editing Font on titleblocks below elevations/plans on sheets? |
Tue, May 22, 2007 at 4:46:36 PM
Elevations and plans all messed up |
Mon, Dec 16, 2013 at 1:50:42 PM
Existing Elevations not Referencing Existing Plans |
Thu, Dec 5, 2013 at 3:57:29 PM
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS |
Mon, Mar 5, 2007 at 2:39:54 PM
