13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Wall type within a window family
24 Posts No Rating |
Hello all. I am trying to create a new window family for a project I am working on. Attached is a .jpg of the design of the window I am striving for. Thus far, I have created the window itself, with mullions, parametric, etc. What I am hoping to do is put a wall inside the window family that will be able to be scheduled/keynoted in the drawings. The reason for doing this is a mostly a construction one (which might be the cause of the difficulty). I have a masonry wall that will be built to the size of the opening for the window. A stud wall will then be built inside this opening. If I have the window cut around the stud wall, I would have to then edit each wall that window occurs in to create my own opening and infill it by hand. Is there any way to do what I am trying to do? Thanks for any help!
Think about doing this as a group of elements rather than a single family. You could use: - An opening to cut your base wall
- Your infill stud wall
- Your window in the stud wall
parametric window should recognize wall type! |
Wed, Apr 12, 2006 at 7:44:20 AM
What type of window are these????? HELP~~ |
Sun, Feb 19, 2012 at 2:47:53 AM
Changing a family type (from door to window) |
Mon, Aug 18, 2014 at 8:59:56 AM
Window will not load into a wall in a project - working in it's own family tho.. |
Mon, Jan 24, 2011 at 9:49:53 PM
window insertion error |
Fri, Apr 13, 2007 at 11:21:46 AM
