Forums >> Revit Structure >> Technical Support >> CONCRETE WALL REINFORCEMENT VOLUME & AND STRUCTURAL TRAINING COURSES
Wed, Sep 19, 2007 at 12:01:03 PM | CONCRETE WALL REINFORCEMENT VOLUME & AND STRUCTURAL TRAINING COURSES
orlabre67
I THINK THERE IS STILL A PROBLEM WITH REVIT´S WALL REINFORCEMENT CALCULATION. IT IS ABOUT 14% HIGHER THAN MANUAL CALCULATIONS. I NEED SOME HELP ON THAT. ALSO, I AM LOOKING FOR A STRUCTURAL TRAINING COURSE WHICH CAN HELP US DEVELOP AN EASIER WAY TO ESTIMATE LARGE QUANTITIES OF STEEL REINFORCEMENT AND CLASSIFY THEM BY DIAMETER. I HAVE TO ESTIMATE  STEEL REINFORCEMENT WEIGHT TOTALS (KG) AND CONCRETE VOLUME (WHICH IS EASY BY THE WAY). I AM USING REVIT STRUCTURE 2008. AND I THINK THIS VERSION HAS MANY GOOD THINGS BUT IT HAS A LONG WAY TO GO IN STEEL REINFORCEMENT CALCULATIONS!
THANKS,
ORLANDO
Material Volume out of Material Takeoff
Sat, Aug 9, 2008 at 7:23:48 AM
Schedule concrete volume (including column, slab & beam) by workset
Thu, Oct 28, 2010 at 8:04:52 AM
Low cost BIM Training and Revit Technical Training
Wed, May 2, 2012 at 7:51:54 AM
structural framing vs scheduling (volume report)
Fri, Feb 25, 2005 at 11:15:12 AM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Page generation time: 0.7608
