Forums >> Revit Building >> Technical Support >> Half Toning a Plan Region RAC 2008
Tue, Sep 18, 2007 at 2:19:02 PM | Half Toning a Plan Region RAC 2008
JHPBCJ
Is there any way to half tone a plan region?  My example is that on my ground floor plan, I want to be able to show a Loading dock area which is outside the building line and a level below, but with lighter/greyer lines - so i started by making a plan region.  I guess this would also apply to seeing roofs below in half tone.
I tried changing the lines in V/G but this only changed the actual outline of the plan region, not the "window view".
thanks.
Tue, Sep 18, 2007 at 3:50:37 PM | Half Toning a Plan Region RAC 2008
sdbrown
5 Stars: 3 Votes
Set the plan region leave the primary view range as is but change the view depth(the bottom box) to the level below. ths will put the objects on that level to the Beyond linestyle. Check your object styles and make sure your beyond linestyle is set to a grey color.
Half toning everything but Design Options?
Tue, Jan 26, 2010 at 11:22:27 AM
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:48 AM
15
Why Roof Cutplanes are visible in RAC 2008 and Why not in Revit Building 9
Wed, Jul 16, 2008 at 10:34:18 AM
Wall disappears when plan region applied -RAC 2008
Mon, Aug 27, 2007 at 2:23:25 PM
Room Tag not visible using Plan Region? RAC 2009
Wed, Aug 19, 2009 at 12:26:44 AM
Page generation time: 1.3708
