Forums >> Revit Building >> Technical Support >> Room Shared Parameters
Thu, Sep 13, 2007 at 1:20:09 PM | Room Shared Parameters
broncos4life
3.5 Stars: 11 Votes
I am trying to add a shared parameter to rooms so that I can tag them and have it be a smart tag.  I make mods to my room tags and add parameters that I need, but then when I go in my project I can't find or use thoes parameters.  Is there a way around this?  Why can't you add shared parameters to rooms?  Or is there a way to link a project parameter to tags?
Tue, Sep 18, 2007 at 9:33:21 AM | Room Shared Parameters
TomDorner
4.5 Stars: 25 Votes
You have to add theshared parameter to the room tag family AND to the project you are trying to
use the room tag family in (assign to room category).
If the parameter is something you are always going to use, then add it to your template file as well.
Tom
Creating Room Tags with shared parameters
Wed, May 20, 2015 at 11:56:07 AM
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Version 2009 - Shared Parameters and Key Schedules
Fri, Jan 30, 2009 at 1:49:25 PM
Room Tag Parameters
Wed, Feb 2, 2005 at 8:05:26 PM
Using alle the project parameters in label (not shared parameters!
Fri, Nov 30, 2012 at 7:23:04 AM
Page generation time: 3.0012
