Forums >> Revit Structure >> Technical Support >> Trouble with Arch file in Structure
Wed, Sep 12, 2007 at 2:13:22 PM | Trouble with Arch file in Structure
nmartin
I am having a problem opening a Revit file sent to me by an architect. When I attempt to open the file I get an error that reads: "An unknown error occured while accessing 'File Path\File_name.rvt.'"
My office uses Structure 2008. I first got the error when the architect was using an older version of Building. When they upgraded to Building 2008, their file opened fine. The last time they sent the file I was getting the same error I noted above. Any ideas as to what the issue is? Or whose end the problem is originating on?
Thu, Sep 20, 2007 at 1:52:00 PM | Trouble with Arch file in Structure
EDGinc
Did you try checking the "DETATCH FROM CENTRAL" option before opening it.
Although, you should be linking to your file, not opening the arch's file anyway, this
might be another work around
Wed, Sep 26, 2007 at 9:24:13 AM | Trouble with Arch file in Structure
nmartin
I did "Detach from Central" and got the same error. I also get the same error when I attempt to link the arch file into my structural file. I'm thinking this is an issue on the architects end. I was hoping that maybe someone else had seen this occur before.
Hello All! Moving Revit Arch Drawing to Revit Structure Problems
Thu, Feb 12, 2009 at 8:18:59 AM
Central File & its Arch link - disappeared!
Mon, Aug 29, 2011 at 2:54:22 PM
Arch link on top of Structure
Wed, Jul 20, 2011 at 4:27:19 PM
Slabs drawn in Arch used in Structure?
Thu, Jul 17, 2008 at 9:20:19 AM
Cannot see arch object when model is linked into revit structure from revit arch
Fri, Jan 22, 2010 at 9:58:53 AM
11
Page generation time: 1.9086
