11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Linking the same revit model into a site with different RL's
1 Posts No Rating |
Can anyone out there help with the following situation: We are currently working on a townhouse development where we are repeating designs over the site. We are using a master site plan and importing the Revit models into the site drawing which has all the topography and so on in it. The problem is we need some of the repeated models to have different levels on the site - is there a way to achieve this?
Why don't you try seperate files for each one set at the right elevation and linked seperately.
Does just moving the building up or down not work for you? I'm sure I'm missing the problem. Create the levels you need in your master(site) and turn off the levels in the links.
Site Plan Linking |
Wed, May 10, 2006 at 8:03:23 AM
Linking models with multiple sites |
Wed, Dec 6, 2017 at 9:43:09 AM
Linking buildings to a site |
Thu, Sep 16, 2010 at 4:28:48 PM
Linking structural model to architectural model |
Tue, Oct 9, 2007 at 6:05:11 PM
Linking AutoCAD Site Contour missing 2014 |
Wed, May 27, 2015 at 7:56:32 AM
