11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Light fittings in ceiling grid
I have placed 600 sqaure light fittings (standard revit items) in a 600 square ceiling grid. This is how they appear on both ceiling plan view and 3d wire frame.
I have had to move ceiling grid 300mm to bring central to room for even cuts, but this was before I did any renderings/raytracing or even added the lights.
However, when I render, the ceiling grid does not correspond to the model ceiling grid and therefore lights are no longer on grid. How can I adjust the "render"grid to match the "model" grid.
This is a FAQ,
You need to adjust the map position for the ceiling material in the accurender settings, it is a matter of trial an error really.
Thank you. It takes some time though.
With scaling, map adjustment and a bit of educated guessing you can get it looking pretty good pretty quick.
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS |
Thu, Dec 15, 2005 at 10:30:38 PM
Light Fittings in Legend |
Tue, Oct 6, 2015 at 10:41:28 AM
Light fixture that snaps to ceiling grid? |
Thu, Jun 21, 2012 at 6:50:38 PM
Ceiling objects cut by walls |
Fri, Nov 20, 2009 at 12:58:09 AM
How to see ceiling grid in 3D view in REVIT? |
Sun, Jul 24, 2011 at 10:31:31 AM
