Forums >> Revit Building >> Technical Support >> design options tied to other objects (version 2008)
Tue, Sep 11, 2007 at 7:58:17 AM | design options tied to other objects (version 2008)
JHPBCJ
I am very new to Revit and I am having a really hard time with design options.  I can't even add walls in the main model now without getting errors about the objects being related to design options.
there just seem to be so many limitations in design options, are they even worth using?
Mon, Mar 31, 2008 at 5:40:17 PM | design options tied to other objects (version 2008)
poservex
i'm going through this issue as well.  in residential architecture it's all about multiple elevations and multiple options per plan.
 I believe the issue we're both experiencing has to do with wall sweeps and/or elements hosted on a certain wall that was added to another design option previously.  the only work around i've been able to find involves a lot of copy pasting of the issue walls and tons of redoing all the phase setting on additional elements that are brought over from being linked to an element while existing in another phase.
Tue, Apr 1, 2008 at 6:17:36 AM | design options tied to other objects (version 2008)
Design options are tough until you understand the rules.  Basically they are:
  1. You can not edit a design option element unless you are in the edit function for that option.
  2. Hosted elements can only be hosted by elements in the same option.
Design options work pretty well and se have used them for complicated projects.
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Text In Design Options Revit 2008
Wed, Aug 15, 2007 at 9:22:26 AM
Design Options - black hole.
Wed, Feb 14, 2007 at 12:54:40 PM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
Multiple design options - glitch?
Fri, May 23, 2014 at 9:24:32 AM
Page generation time: 2.2845
