Forums >> Revit Building >> Technical Support >> vertical brick pattern
Mon, Sep 10, 2007 at 6:47:26 PM | vertical brick pattern
erpdesign
now i know you can rotate surface patterns. I was wanting to create a brick header in the window family but once i give the pattern in the family i can't rotate it when loaded into the project. Does anyone have a vertical brick patern??
Mon, Sep 10, 2007 at 8:39:54 PM | vertical brick pattern
sdbrown
5 Stars: 3 Votes
For a soldier course just create a surf. pattern using the parallel lines in the fill pattern dialog, selct the spacing you need. ie 2.667" with a rotation of 90, If you have multiple, check the box for cross hatch and set the horiz/ to 8"
Tue, Sep 11, 2007 at 3:08:31 AM | vertical brick pattern
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
HI try this one.
See you
-paolo
VERTICAL BRICK PATTERN
Thu, Oct 19, 2006 at 10:23:25 PM
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Help with brick hatch
Mon, Oct 27, 2008 at 5:39:36 PM
11
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
Page generation time: 0.4364
