Forums >> Revit Building >> Technical Support >> LINTELS
Mon, Sep 10, 2007 at 4:50:01 PM | LINTELS
bluenose
Help (I am obviously stupid).
Where are the lintels located in Revit?  I draw extensions for planning permision in the UK so Catnics or similar would be useful.
Mon, Sep 10, 2007 at 5:03:04 PM | LINTELS
Stone ?  Concrete ?  Steel?   Detail component ?  Model ?
More specifics please.
Mon, Sep 10, 2007 at 8:51:54 PM | LINTELS
sdbrown
5 Stars: 3 Votes
I typically add them to the window family.
Mon, Sep 10, 2007 at 9:08:25 PM | LINTELS
bluenose
Catnic Lintels are steel, typically 150mm deep or 225mm deep depending on the opening.
At present I draw some of my drawing in revit, then export it to autocad and touch up various components (such as lintels) manually.  I do the same with trusses or rafters and floor joists and all foundation details in my sections.
I am hoping to improve!
Tue, Sep 11, 2007 at 12:52:11 PM | LINTELS
sdbrown
5 Stars: 3 Votes
In revit you would just make a profile of the angle (steel shape) then load that into your window family and do  a sweep the width of your window + the distance you want it to extend on each side and chose the profile you created. then finish the sketch and make sure the object is on a subcategory for steel and probably set it to only display at fine level of detail.
Lintels in Revit Structure
Mon, Nov 5, 2007 at 10:31:29 AM
masonry lintels
Thu, Jun 12, 2008 at 12:58:13 PM
How to create masonry or concrete lintels and display them correctly?
Fri, Apr 9, 2010 at 3:42:59 PM
Overhead Lintel - Doors and Windows
Wed, Mar 22, 2006 at 4:23:48 PM
Lintels
Thu, Feb 16, 2006 at 12:34:49 PM
Page generation time: 0.0401
