Forums >> Revit Building >> Technical Support >> Surface pattern
Mon, Sep 10, 2007 at 9:46:46 AM | Surface pattern
utearch1
I am looking for a dry stack cultured stone surface pattern, as well as a rendering material that will match that pattern. I have tried the surface pattern on the downloads, but it doesn't work. It just shows up as black.
I am using 9.1 if any one has anything.
Thanks
Mon, Sep 10, 2007 at 11:18:01 AM | Surface pattern
JLink
did you ever try applying a texture pattern jpeg image to your component in revit?  its an easy process and you can map any texture from regular picture files.  it doesnt show in your plan views but appears when you raytrace/render.
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
voronoi surface pattern
Fri, Jun 24, 2011 at 2:14:03 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Page generation time: 0.2381
