Forums >> Revit Building >> Technical Support >> How do i model this kind of baluster and this railing? (image inside)
Sun, Sep 9, 2007 at 4:01:11 PM | How do i model this kind of baluster and this railing? (image inside)
samov
 I tried to model it using a baluster family and then select in the railing tool...
 Every time i try to finish the railing i end up with an error message and it asks me to delete the balusters.
 Does  anyone have a step by step guide or can offer any help?
Mon, Sep 10, 2007 at 8:25:53 AM | How do i model this kind of baluster and this railing? (image inside)
Check out these railings.  One is similar to what you are doing.
http://revit.autodesk.com/library/html/Revit%20Instruction%20&%20Help%20Samples/Revit%20Samples/Imperial/index.html
Baluster inside Newel Post revit 2014
Wed, Mar 26, 2014 at 2:54:06 AM
Newbie help: how to intersect railing with baluster
Wed, Mar 25, 2009 at 4:26:53 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:20 PM
Balusters and Railing Help
Wed, Jul 7, 2010 at 1:39:31 PM
Baluster connectors not staying parallel to railing.
Mon, Apr 12, 2010 at 3:37:59 AM
Page generation time: 3.2911
