Forums >> Revit Building >> Technical Support >> Drawing Sheets
Sat, Sep 8, 2007 at 1:41:11 PM | Drawing Sheets
Westview
2.5 Stars: 2 Votes
I would appreciate some help with the following question.
I understand how to make and add shared parameters to Drawing Sheets that show up as editable blue question marks on a sheet to sheet bases. What I can't figure out is how to make a parameter that I can change on all the sheets and will show up under Settings / Project Information.
Thanks for the help
Sat, Sep 8, 2007 at 11:42:47 PM | Drawing Sheets
Tony
Instead of ticking "Drawing Sheets" tick "Project Information" instead
Sat, Sep 8, 2007 at 11:45:15 PM | Drawing Sheets
Tony
Sorry I should have said when inserting the shared parameter,
Instead of ticking "Drawing Sheets" tick "Project Information" instead under categories
Sheets showing in Architectural Drawing list but not in project browsers?
Wed, Jan 11, 2012 at 8:08:35 AM
Drawing list sheets are in incorrect order
Fri, Jul 9, 2010 at 10:59:05 AM
Sheet Number Already in Use...I have ghost sheets.
Tue, Nov 21, 2017 at 8:47:10 PM
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Drawing List's
Wed, May 26, 2010 at 11:49:42 AM
Page generation time: 1.9322
