Forums >> Revit Building >> Technical Support >> Ref planes
Wed, Feb 2, 2005 at 5:37:43 PM | Ref planes
shaun_kiwi
5 Stars: 2 Votes
I wish to constrain a referenece plane that is not parallel to another such that it rises with the other when an adjustment is made. How do I do that?
Wed, Feb 2, 2005 at 7:57:53 PM | RE: Ref planes
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Providing your using version 7 use reference lines as opposed to planes as this way you can dimension to the end points to adjust height etc. HTH.
Wed, Feb 2, 2005 at 9:31:25 PM | RE: Ref planes
shaun_kiwi
5 Stars: 2 Votes
Thank-you that solves one problem I was having. The rest of my lighting family problems were solved yesterday when I realised I was using version 6.1 templates with version 7.0 revit. Somehow this affected modelling. We loaded current templates rather than going throught the upgrade process over and over and problems vanished.
Wish List - Toggle Reference Planes
Fri, Sep 24, 2010 at 1:23:59 PM
how to change defined ref planes in a family
Mon, Apr 18, 2011 at 2:07:00 AM
How Can I Change The Dimensions Of A Window To A Specific Custom Size?
Tue, May 26, 2009 at 7:28:02 AM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Nested Family won't lock to 2 ref planes/lines
Fri, Jan 17, 2014 at 10:09:19 AM
Page generation time: 1.3559
