8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> roof plan
16 Posts No Rating |
I am trying to get a roof plan that shows the support walls. To acomplish this I was able to use wire mesh view and filter out all but the external support walls. My problem is that instead of just getting clean roof lines I get 3 lines at each roof intersection. These extra lines disappear if I use hidden line view but then I loose the support wall see through. Is there any way to get a clean roof plan and see the support walls through the roof???? Help appreciated. BarryS
Hi, why don't you use a ceiling view? you will see the wall support properly cutted by the view and you'll able to edit the roof. If you're interested in a top side view of the roof you can always put under the roof view the last level plan view:it will appear grey out but you can redraw very quickly the line of the walls you need. Take a look at the view properties and change None to "the last level". Hope this help you a little bit. -paolo
Roof Plan Issues- lower roof showing above upper roof |
Thu, Dec 10, 2015 at 3:10:46 PM
Roof plan |
Fri, Sep 2, 2016 at 4:58:14 PM
Walls disappear in roof plan after attaching to roof. |
Wed, May 30, 2012 at 11:36:02 PM
Creating a Roof Plan in Revit |
Wed, Oct 3, 2007 at 8:51:58 AM
missing roof in roof plan |
Thu, May 7, 2009 at 11:40:59 AM
