Forums >> Revit Building >> Technical Support >> Plan moves with wall
Fri, Sep 7, 2007 at 3:45:38 PM | Plan moves with wall
cberg
Everytime I move a certain exterior wall it moves the entire plan (actually most of the building) with it.  When I select the wall I select detach top and bottom but nothing seems to happen.   Is there a way to make this not happen?
thanks
Fri, Sep 7, 2007 at 3:54:11 PM | Plan moves with wall
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
hi, when creating the plan did you pick those wall? did you copy the level selecting levels by name? maybe that's the reason why it seems to work not properly.
Hope this help you a little bit.
-paolo
Sat, Sep 8, 2007 at 8:25:07 AM | Plan moves with wall
First, make sure you have just the wall and not a chain of walls.  After you hit the move button, look at your optios bar.  You need to press the button that unjoins this wall from everything, not just top and bottom.
Wall Reservation Lines in Plan
Thu, Oct 19, 2017 at 9:07:58 AM
Editing a Floor Plan That Doesn't Show up on The 3D Model
Sat, Dec 12, 2009 at 10:15:58 PM
Copying issue. Objects copied automatically go to floor above
Wed, Nov 19, 2014 at 2:22:11 PM
REINFORCING MOVES MODEL
Thu, Oct 6, 2005 at 3:36:36 PM
Creating a new object and orgin moves
Thu, Jan 15, 2015 at 1:51:27 PM
Page generation time: 4.7478
