Forums >> Revit Building >> Technical Support >> View Range > Cut Plane - Greyed out?
Fri, Sep 7, 2007 at 3:31:42 PM | View Range > Cut Plane - Greyed out?
justinblack
Can someone please explain to me why when I got to View Range, the Cut Plane (pulldown) is always greyed out?  Is there a way to change this?  Thanks
JB
Fri, Sep 7, 2007 at 3:46:17 PM | View Range > Cut Plane - Greyed out?
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
Hi, this is due to the origin of the plan view you're in: any plan view is associated to a level, plan views could not exist without a level, but the contrary does. So when you define the cut plane you're not allowed to change the reference level but only the distance between the ref. plane and the cut plane.
-paolo
bottom view in view range is not active, why?
Tue, Apr 24, 2012 at 7:22:57 AM
View range queations
Mon, Jan 18, 2010 at 4:48:17 PM
View Range Cut Plane Associated Level is wrong
Fri, May 4, 2012 at 11:46:09 AM
View properties "cut plane" option greyed out?
Thu, Dec 11, 2008 at 6:57:03 PM
question using view range
Mon, Apr 6, 2009 at 1:41:24 PM
Page generation time: 1.6320
