Forums >> Revit Building >> Technical Support >> Font issue?
Wed, Feb 2, 2005 at 3:01:08 PM | Font issue?
JimmyJack
Hey gang, new user here.... Our Autocad setup uses archstyle.shx. I have set up our office template for Revit using a handdrawn font called HANDSFN.TTF. In Revit, text comes out looking fine (12'-0", for example), but dimension text comes out looking like 12' - 0". It appears that there is a space on both sides of the "-". Is there a way to format dimension text to appear as regular text? Thanks bunches
Wed, Feb 2, 2005 at 4:25:23 PM | RE: Font issue?
arnosandoval
5 Stars: 3 Votes
If you go to Settings-Annotations-Dimensions-Linear, you are given the properties of linear dimension, which infludes text, spacing, units, etc. That should get you what you want. Quick questions, what does this font look like, I've been looking for a nice architectural handwritten font to use in our offices Revit projects. Thanks.
Thu, Feb 3, 2005 at 2:16:26 PM | RE: Font issue?
JimmyJack
thx for the reply, but I dont see any formatting for my issue. reply with your email, I can send some fonts that may work for you.
Thu, Feb 3, 2005 at 2:25:30 PM | RE: Font issue?
arnosandoval
5 Stars: 3 Votes
That didnt work I'm surpriced. Sorry that it didnt work. I checked it out and its something predefined that we can't mess with. There is no width text factor that one can mess with like one can in plain ACAD. Email. sandovala@pbworld.com Thanks in advance for the fonts.
Wed, Feb 7, 2007 at 8:45:57 AM | Font issue?
kevins
How do I globaly set the font in Revit to "StylusBT"? This the font our office has agreed to use as a standard. I change the font for notes, but the titles remain in Arial. This has to be easy. I just don't know which button to push to make it happen. All comments welcome.
Thank you.
Wed, Feb 7, 2007 at 9:32:57 AM | Font issue?
arnosandoval
5 Stars: 3 Votes
Can't do it. Have to change the text for all the tags (with the exception of  elevation tags, those you can change under Settings_View Tags_Elevations) the rest are under the family for the tags. The text you can change in the properties of  the text. The dimensions are the same, you can also go to Setting_Annotations_Dimensions Linear and make the changes there. Hope this helps.
Tue, Feb 13, 2007 at 12:50:15 PM | Font issue?
courthouse
I have recently moved to a company that has been using revit in a large capacity but without really setting standards.  I'm in the process of trying to remedy this situation.  I'm currently using the "stylus BT" font but would like to move to something a little more architectural, I've seen everyone tossing around font names (i.e. "handsfn.ttf"Winking but I haven't been able to find any samples of some of these fonts to preview before asking the company to purchase.
 In addition, I've gotten new D and E size titleblocks designed but I'm having trouble finding a format (other than the revit standard) for an 8.5x11 for sketches.  If anyone has a sketch titleblock that I can reference in order to set up our sheet.
Tue, Feb 13, 2007 at 2:57:51 PM | Font issue?
arnosandoval
5 Stars: 3 Votes
Attached are the the architectural fonts that I use at my office. Hope these files can help you. Regarding the titleblocks Revit has a 8.5x11 titleblock in the program that you can change, or you can create a new titleblock family by going to File_New_titleblock, and make the sheet whatever size you want. Hope this helps.
Tue, Feb 13, 2007 at 3:11:45 PM | Font issue?
courthouse
Thanks for the file, I'm sure it'll help.  As for the titleblock I'm familiar with the revit layout, I'm just looking for some other examples that I can reference to create my own.  You know, combine the best portions of all I can find into one.
 Thanks again
Architectural font issue
Wed, Oct 26, 2016 at 2:39:09 PM
Missing Grid Lines ...again
Fri, Mar 28, 2008 at 10:39:23 AM
Diemension Issue in Revit 2011 version
Thu, Jun 30, 2011 at 8:52:55 AM
Tag issue in floor plans
Mon, Mar 16, 2009 at 7:16:31 AM
Importing old Font
Tue, Sep 11, 2007 at 9:32:29 AM
Page generation time: 2.4128
