Forums >> Revit Building >> Technical Support >> Title Position
Wed, Feb 2, 2005 at 9:28:04 AM | Title Position
quiller
quiller Avatar
2.5 Stars: 3 Votes
If I rotate a view on a sheet, is it possible to also rotate and move the title so it's at the bottom of the view when I'm finished? Cheers......Alan
Wed, Feb 2, 2005 at 5:25:04 PM | RE: Title Position
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes. Instead of using the view properties, rotation on sheet tool. Select the crop region of the view and rotate 90º, this will effectively rotate the view but leave the view title at the bottom. HTH.
Thu, Feb 3, 2005 at 1:13:38 PM | RE: Title Position
quiller
quiller Avatar
2.5 Stars: 3 Votes
Hi, I don't follow. If I rotate the crop region (at the floor plan level) the only thing that rotates is the crop, not the view. I want to place the views on a sheet so they read better, if you take a look at the attacted doc, it may help. Cheers......Alan
Thu, Feb 3, 2005 at 5:32:23 PM | RE: Title Position
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Bugger i'm sure that used to work. The only other way i can think would be to create a new view title where the text is rotated. You could then use this for the rotated views. HTH.
viewport title with line question
Tue, Jul 8, 2008 at 11:38:17 PM
Viewport title locked. How to unlock?
Tue, Sep 30, 2008 at 3:20:48 PM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Aligning text position in different labels.
Fri, Sep 25, 2009 at 9:48:29 PM
Title Block - How do I insert a drawing title?
Fri, Apr 20, 2012 at 12:18:43 PM
Page generation time: 5.0379
