10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Isolating Family Type
Revit 8.1 Hi, I was wondering is there a way to isolate family type insteads of family category... Doing phasing with curtain wall and brick wall & alum composite panel all on sometime is really confusing. Isolate wall type would indeed do the tricks insteads of hide off objects one by one Thanks
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
Hi, in 8.1 i believe that you can't isolate directly a family type from the view properties but you can always select the family type you're interested in from the project browser (there's a list of all the family types you're using in your project an even more!), then you can select all the istances of that and then isolate the object from the view command (maybe would be properly renamed "Isolate selection" . For exampleif you follow Families\Walls\Basic walls\Brick wall > select all the istances you have a quick selection of all the objects that belong to the brick wall family type; go on the light bulb and select isolate object to have a "family filter" view. Hope this help you a little bit. -Paolo
Editing Family Type |
Tue, Sep 21, 2010 at 3:58:31 PM
excluding a type in the family type parameter |
Thu, Mar 20, 2008 at 3:38:32 AM
ISOLATING FLOOR LEVELA IN 3D VIEW |
Thu, Feb 12, 2009 at 11:55:51 AM
How to find the missing void object in family |
Wed, Apr 23, 2008 at 12:09:08 AM
Create New Family Type for Drop Down Menu Family Parameter? |
Wed, Nov 16, 2016 at 5:48:00 PM
