11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Relief Area
56 Posts No Rating |
I have an EIFS wall that I need to cut a large relief in. What is the best way to do it? The EIFS is 1 1/2" thick, and I want to create a shape that will cut-out 3/4" into the EIFS. Using 9.1 Thanks
Vertical or Horizontal? If horizontal you can put a reveal in the properties of the wall->edit new-> then make sure your preview is in section and with that you can cut a horizontal reveal into the wall. (You can also make bump outs in the wall this way as well.) If they are Vertical the only way I know how to do that is by making a wall hosted generic model that cuts the wall.
You can also use a hosted reveal. They can be changed from horizontal to vertical.
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
Area Plan does not match Area from Materia/l Area |
Tue, Feb 13, 2018 at 7:50:03 AM
Unusuall wall relief and window brick arch |
Sun, Dec 5, 2010 at 4:00:08 PM
Area Plans |
Wed, Nov 1, 2006 at 10:03:12 AM
Revit 2011 products crash when attempting to replace material render appearance |
Tue, Jul 5, 2011 at 10:44:16 AM
