22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Copy during Align command?
Is there a way to copy something with the align command? Just like there is the 'copy' check box during the Mirror(MM) command? Thanks, Lorne
Denver, CO
Revit Architecture |
You can always, choose something... Then Ctrl+C (copy to clipboard) and then Edit > Paste Aligned > Same Place. This will bring up a warning if you select an object vs a line. Then just align the object again and you will have 2 like you requested. Other than this I don't think there is a way to copy with the align command. No there is no toggle on/off like the mirror command. HTH JB
Ok thanks JB. Also everyone types HTH. What does that mean?
Denver, CO
HTH - Hope that Helps
Collaborate - Copy command changes type |
Fri, Nov 6, 2015 at 1:35:14 PM
Revit wont align siding |
Fri, Dec 2, 2011 at 8:46:33 AM
Auto Lock on align command |
Wed, Mar 7, 2012 at 9:07:46 AM
Move/Copy/Align Masses |
Thu, Jan 10, 2013 at 8:44:30 AM
Copy/Monitor Lights to Revit Architecture 2012 |
Wed, Oct 17, 2012 at 3:05:52 PM
