Forums >> Revit Building >> Technical Support >> Changing Floor Area Face Material
Wed, Sep 5, 2007 at 1:03:02 PM | Changing Floor Area Face Material
jenmckeel
Does anyone know how to change the material applied when you apply a floor area face to a mass using the "Floor Area Faces" button in the option bar?  Under Settings>Materials, you can duplicate and change the "Default Floor Area Face" material, so I would think there would be a way to apply a new floor area face material.  But I cannot find where one would do this!
I am building a conceptual, transparent massing model where it is helpful to see the different levels, and I would like the floor area faces to be different colors to correspond to my different types of masses.  I am using Revit Architecture 2008.  Any help is appreciated!
Fri, Sep 7, 2007 at 3:17:08 AM | Changing Floor Area Face Material
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
Hi, I solved the problem using a mass family: create the family of your concept with volumes etc. in mass family; add a material parameter (instance) and assign it to each volume in your family, save it and upload it in the project.
Duplicate the mass material you want and assign to each volume separatly the material you need.
Or if you prefer use the paint bucket and pick all the sufrfaces of your concept mass.
Hope this help you a little bit.
-Paolo
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Modifying Split Face
Thu, Feb 18, 2010 at 6:07:10 AM
Face Region: How to check for material used?
Thu, Aug 27, 2009 at 12:26:17 PM
Split Face + Material Takeoff
Mon, Jan 28, 2013 at 6:23:50 PM
Material ID and Element ID
Tue, Sep 23, 2008 at 8:45:21 AM
Page generation time: 0.7508
