14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Flushed Wall & Column
6 Posts No Rating |
Newbie here - How do I remove the line between column and wall? the column is concrete, while the wall has a structure of masonry and concrete for finishes. i've tried using structural columns but the material overlaps with the wall. is there a clean way to do this or am i just missing something?
Turn of wrapping at ends on your wall type, the use join geometry.
6 Posts No Rating |
thanks for the reply sdbrown, whenever i use join geometry, the column absorbs the material of the wall. is there a way to keep the column material as is and have a clean elevation? after all the finish of the wall is the same as the material of the concrete. there is a workaround that i found, instead of using columns i'll use thick walls as to build my column and unjoining geometry. it shows up the way i want on plan and in elevation (see attachment). but is there a possible problem with this workaround? especially when coordinating drawings with engineering consultants?
There are two different columns in REVIT. One works like a pilaster and will take on the material of the wall. The other is structural and you set the properties. Use the correct one and you won't have any problems.
6 Posts No Rating |
thanks for the tip!
Visibility graphics of a structural column |
Mon, Aug 16, 2010 at 8:21:00 AM
curtain wall at column |
Tue, Sep 8, 2009 at 12:24:40 PM
Beam & Column tags |
Tue, Jun 14, 2005 at 4:48:53 AM
Trouble with wall & steel column intersection and joist placement. |
Fri, Dec 16, 2011 at 9:34:11 AM
Wall / Column Sweep |
Mon, Nov 13, 2006 at 9:37:37 PM
