Forums >> Revit Building >> Technical Support >> Calculating Volume
Tue, Sep 4, 2007 at 2:35:09 AM | Calculating Volume
magnic
I can generate volume if I use a structural family template, but I can't use this volume for calculating weight for example. I can only define the volume by myself, with length, width and height, and thén use this parameter for calculating. I use a lot of round profiles and objects and that's too difficult to define the total volume.
So I want to use the automatically generated volume from the structural family template.. Is this possible?
 I can use the volume if I could set off single objects. But that's my second question. I can make single objects within a family invisible. But when I have a family I want to set a single object off. When I make the single object invisible he still calculates the volume. I want to use a parameter (yes/no) to set a single object off so he doesn't calculate the volume.
Revit 2008. Volume not calculating. Any suggestions?
Mon, Apr 11, 2011 at 8:35:14 AM
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
CALCULATING THE RIFLE PIT ?
Mon, Jul 28, 2008 at 4:00:31 PM
Taking off material volume
Wed, Feb 22, 2012 at 4:08:50 AM
conc volume
Mon, Apr 11, 2011 at 9:21:01 AM
Page generation time: 0.3592
