Forums >> Revit Building >> Technical Support >> Level Heads in Drafting Views
Mon, Sep 3, 2007 at 10:48:22 PM | Level Heads in Drafting Views
Binnsdrafting
Can I pull level heads into drafting views or do I need to create a detail component for this?
I would prefer to link the Drafting view to the section callout with the levels as shwon in that section but want to use my own drafting rather than lineworking the detail to death.
I'm using Revit Arch 2008 - thanks for your help!
Tue, Sep 4, 2007 at 11:55:05 AM | Level Heads in Drafting Views
Cut you section then turn off all of the model elements that you don't need.  Keep the annotation levels.
Tue, Sep 4, 2007 at 12:59:58 PM | Level Heads in Drafting Views
Binnsdrafting
For something so obvious I should have known - thank you for the help.
level heads
Thu, Sep 7, 2006 at 5:34:27 PM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
scaling of level head, grid heads etc
Thu, May 25, 2006 at 6:07:37 PM
Converting Model Views to Drafting Views
Fri, May 13, 2016 at 2:13:29 PM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:28 PM
Page generation time: 0.4066
