Forums >> Revit Building >> Technical Support >> Copy with line divisions
Thu, Aug 30, 2007 at 4:36:52 PM | Copy with line divisions
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello,
I'm trying to copy a column along a wall.  I want there to be 4 columns or maybe 3 along a wall that are equally spaced?  How do I do this?  I know in ArchiCAD you can just select 'Divisions' and as you're copying the object tick marks show up and it snaps into place depending on how many divisions you set it too.  You can do 10 or 100.  Is there a quick easy way with Revit?  Thanks,
Lorne
Denver, CO
Revit Architecture
Thu, Aug 30, 2007 at 5:01:46 PM | Copy with line divisions
broncos4life
3.5 Stars: 11 Votes
You can array "Last" if you know the start and end point, and then change how many instances will happen in that array.  I think thats what you mean.
line showing up on walls
Thu, Jun 8, 2006 at 8:08:34 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
curtain wall divisions 5ths
Fri, Mar 19, 2010 at 11:21:21 AM
Masterformat Numbering... Which to use?
Tue, Mar 17, 2009 at 8:56:47 AM
Sheet Divisions
Wed, May 13, 2009 at 12:00:46 PM
Page generation time: 2.2304
