Forums >> Revit Building >> Technical Support >> Printing views to scale?
Thu, Aug 30, 2007 at 3:09:51 PM | Printing views to scale?
cberg
May sound obvious, I thought it should be but how can I print, not on a sheet, progress elevations, all at the same scale.  I set the scale at "1 to 20 feet, scale it to 50% onto 11 x 17 sheets but they all come out at differenct scales.  DO I have to put them on sheets?
Thu, Aug 30, 2007 at 3:30:01 PM | Printing views to scale?
If your view will fit on the sheet that you are printing to with the scale as you have it set, then just print it @ 100% & centered.  It will print correctly.   DON'T SCALE TO FIT
Fri, Aug 31, 2007 at 8:33:25 AM | Printing views to scale?
cberg
thank you.
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale.
Tue, Sep 6, 2011 at 7:51:06 AM
Printing
Tue, Oct 5, 2010 at 6:38:41 PM
Rendering Elevation 3d views with scale
Tue, Aug 14, 2012 at 9:43:43 AM
Printing an A1 sheet
Mon, Mar 18, 2013 at 3:21:14 PM
printing to scale
Fri, Nov 5, 2010 at 12:17:57 PM
Page generation time: 0.3031
