Forums >> Revit Building >> Technical Support >> In my callout door jamb detail, I can't get the masking area to.................
Thu, Aug 30, 2007 at 2:50:33 PM | In my callout door jamb detail, I can't get the masking area to.................
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Revit 9.1................go to the back to allow inserted detail components to be visible.  I have inserted the manufacturer's door jamb CAD drawing direct as a .dwg import from the CAD file, I have inserted it into a generic detail family and then used "detail component", and I have created a family file and inserted it as a component.  The masking area brings up draw order boxes when I select it but the "send to the back" button has no effect.  In none of the three tries has the inserted detail component brought up any draw order options when selected.
I have used this process before without any problems.  There must be some simple thing I have done different to cause this fouled up situation.  Any help will be appreciated.
Wall opening setback for door jamb
Tue, Apr 30, 2013 at 8:43:06 AM
Door/Room Tags in Callout Detail
Thu, May 17, 2007 at 3:18:42 PM
Hiding a detail in all views in one step
Thu, Jan 21, 2010 at 2:04:14 PM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
Window Schedule - Jamb, Head, Sill
Wed, Aug 7, 2013 at 4:06:57 PM
14
Page generation time: 1.2344
