Forums >> Revit Building >> Tips & Tricks >> Darker Interior Elevation Boundary Lines
Thu, Aug 30, 2007 at 2:05:59 PM | Darker Interior Elevation Boundary Lines
twhisker
2.5 Stars: 5 Votes
If you want the rectangular boundary box of your interior elevations to be a heavier line (which is an industry standard - hint hint Autodesk), there is an easy fix.
Select the boundary box in the IE view.  Right click and select Override Graphics In View (by category). Change the line weight to a higher value.
BAMM - your boundary box is now a fat line for interior elevations!!
Now for the bigger issue - if anyone know how to make this change permanent to either all projects as a system setting or at least to Interior elevations in general as a view template?
Revit Architecture 2010
Interior Elevations - darker irregular boundary lines
Wed, Oct 1, 2008 at 12:55:15 PM
Darker interior elevation boundary
Mon, Nov 24, 2008 at 11:47:54 AM
Mon, Nov 24, 2008 at 10:35:26 AM
elevation crop boundaries
Fri, Jun 6, 2008 at 5:08:18 PM
Revit 2013- Adjusting the default setting for Interior Elevation crop boundary?
Mon, Aug 26, 2013 at 4:23:48 PM
Page generation time: 2.3267
