Forums >> Revit Building >> Technical Support >> Color Area Plan to PDF files Problems 2008
Thu, Aug 30, 2007 at 8:20:57 AM | Color Area Plan to PDF files Problems 2008
JFK64
GuysI've got a floor plan that I have turned into a colored space plan via Color scheme legend command. Revit file works just like it should, but when I export it to AutoCad and Print it out as a PDF file the color isn't a "complete solid" that encapasses the floor area. In other words some the future shows up as white and some of the floor show up as white (this shoudn't be). Any clues on what is happening??I've included the PDF in question.
why do my text look wonky when I make pdf files?
Mon, Aug 12, 2013 at 12:22:06 PM
Custom Area plan
Mon, May 7, 2007 at 12:11:44 PM
Area Plan Color Scheme Cannot be changed???
Thu, Sep 11, 2014 at 11:58:37 AM
Area Plans with Color Fill Through Walls
Thu, Oct 8, 2015 at 6:50:30 AM
Printing files to PDF format in Revit 2008 Building
Fri, May 30, 2008 at 1:03:04 PM
Page generation time: 5.3364
