Forums >> Revit Building >> Technical Support >> Dimensioning Parallel Curves
Thu, Aug 30, 2007 at 5:51:52 AM | Dimensioning Parallel Curves
Suzanne84
I have two curved walls that are parallel to each other and need to dimension the distance between them (eg width of a corridor) Is there anyway to do this? at the moment I am having to draw detail lines to dimension to which isn't too accurate if anything moves and is time consuming.
Thanks x
Thu, Aug 30, 2007 at 9:57:43 AM | Dimensioning Parallel Curves
broncos4life
3.5 Stars: 11 Votes
Detail lines is the way I would do it as well.  Revit dimensions have to snap to smething not arbitrarty, it can snap to lines and defined static points such as an end point.
Thu, Aug 30, 2007 at 10:22:52 AM | Dimensioning Parallel Curves
If you run a line from the center of the arc's to the outer arc, then you can trim that to the arcs.  Add small pirpendicular lines at each end and this will give you your true dimension.  You can delete the radius line or just place your dimension over it.
Problem is it will not adjust if you change the arcs.
REVIT needs radial concentric dimension capabilities.
Dimensioning 2 non-parallel reference lines
Thu, Feb 14, 2008 at 9:40:47 AM
parallel curtain wall grid on curve?
Wed, Jul 21, 2010 at 6:20:29 AM
sloped curved roof
Sat, Mar 21, 2009 at 7:42:28 PM
Dimensioning a building on the site
Mon, Mar 7, 2011 at 12:12:05 PM
blending curves
Mon, Oct 13, 2008 at 12:22:38 PM
Page generation time: 0.0499
