Forums >> Revit Building >> Technical Support >> Wall wrapping
Wed, Aug 29, 2007 at 4:56:50 PM | Wall wrapping
giz0025
I’m using Revit Arch. 2008.
Is there a way to modify an individual wall wrapping?  I have a wall type that most of the time I want it to wrap at the end.  I’d like to use the same wall type.  I have disallowed join where it butts into an existing brick wall but I don’t want to have the end wrap as it butts up to an existing wall.  Is there a way to change an individual wall end(s) wrapping or do I have to create a new wall and change the end wrap (that would be silly just for an end wrapping)?
Thu, Aug 30, 2007 at 10:19:20 AM | Wall wrapping
broncos4life
3.5 Stars: 11 Votes
Make a different wall type is the only way around it that I know of.  You might also allow the join and play with your wall joins.
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:02 AM
wrapping wall materials
Thu, Aug 14, 2008 at 4:40:22 PM
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:08 PM
wrapping of wall inserts
Fri, Jul 14, 2006 at 5:13:18 PM
Wall wrapping
Thu, Jun 17, 2004 at 6:15:29 AM
Page generation time: 3.5713
