Forums >> Revit Structure >> Technical Support >> Corrupt Imported DWG files
Wed, Aug 29, 2007 at 4:49:01 PM | Corrupt Imported DWG files
superelboogie
I am having issues with my dwg files that I've imported becoming corrupt and crashing revit. Anyone with an answer pleeeeeeez!
Tue, Sep 6, 2011 at 10:12:20 PM | Corrupt Imported DWG files
zlatan24
For working out troubles with dwg data you can use recover dwg. It is able to view the results of restoring. The utility is compatible with all supported Windows OS. The tool is easy to use interface for any experienced users.
Wed, Sep 7, 2011 at 9:55:16 AM | Corrupt Imported DWG files
emgeeo
3.5 Stars: 7 Votes
use the recover and audit features in autocad.
Open a drawing using the recover command.
Once opened, audit with the option to delete corrupted elements.
Wed, May 10, 2017 at 10:49:29 PM | Corrupt Imported DWG files
k065167
6 years later & I still had this same problem! In my case, there were so many imported DWGs in the model that I didn't even know which one crashed Revit Sad
For people desperately looking for a solution like I did, try to remove imported DWGs one by one and see which file is corrupt and delete it. You will probably need a Revit addin for this as there's currently no other way to see all imported DWGs in your file, unless it's small model. Addins like DWG Explorer can do this.
For me, I will make sure to only link dwgs from now on!
Imported dwg files
Wed, May 10, 2017 at 10:25:29 PM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Materials of Imported DWG files
Sat, Oct 17, 2009 at 3:47:08 PM
Drawing Corrupt
Mon, Jan 7, 2008 at 4:06:14 PM
EXPLODING IMPORTED FILES
Tue, Oct 17, 2006 at 2:01:20 AM
Page generation time: 1.1442
