17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Multiple mullions etc
I have been trying to work out how to apply an integer to a parameter such that a number entered would dictate multple divisions in casework or mullions in a window. Help!
You need to setup a label for you array. Once the array is created, select one of the elements and hover over the 2 (no of items in array) and click tab to select the line itself. Then select and add a parameter or link an already created parameter.
If you need a further break down, check out my tutorial.
HTH.
Thank-you for the tutorial. I shed a load of light.
Adding mullions to a window |
Wed, Dec 14, 2016 at 10:19:19 AM
Mullions within in panel family |
Mon, Jun 12, 2017 at 2:32:28 PM
Mullions Won't Stay Put! |
Wed, Feb 19, 2014 at 8:22:02 AM
Curtain wall mullions |
Fri, Jan 11, 2008 at 9:22:15 AM
Corner Mullions |
Fri, Dec 6, 2013 at 11:05:58 AM
