Forums >> Revit Systems >> Technical Support >> Plumbing Fittings
Wed, Aug 29, 2007 at 12:30:11 PM | Plumbing Fittings
NaderB
Hi There,
I cannot find a way to connect back to back plumbing fixtures to a sanitary line, I think I'm missing someting here
Any Idea?
Mon, Sep 10, 2007 at 9:36:49 AM | Plumbing Fittings
gdelfs
4.5 Stars: 3 Votes
Revit does not have any carriers. I have had to adjust my normal design standards to accomodate using Revit. Here is a picture of a couple group restrooms that I had to pipe-up differently than usual. I would regularly use back-to-back carriers, connect the sanitary horizontally(sloped) to a central Water closet, then drop into the slab and connect the vent from each carrier together. I chose to connect each fixture to a horizontal sanitary and circuit vent it. I don't know if your situation is similar.
Custom plumbing fittings
Thu, Oct 1, 2009 at 11:58:05 AM
Plumbing fittings are HUGE!
Mon, Mar 9, 2009 at 9:39:09 PM
Plumbing systems keep blowing up
Mon, Jul 13, 2009 at 1:04:58 PM
Edit Plumbing Fittings
Fri, Apr 2, 2010 at 9:54:14 AM
Dealing with plumbing systems
Fri, Aug 31, 2012 at 5:27:33 PM
Page generation time: 0.0464
