Forums >> Revit Building >> Technical Support >> Step matchline with crop region?
Wed, Aug 29, 2007 at 11:19:51 AM | Step matchline with crop region?
MYoung
MYoung Avatar
Revit Arch 2008
 Our project has a matchline which is stepped, thus creating two L shaped large scale plans.  Is it possilbe to create a crop region that is not rectangular (ie like in autoCAD having a poygon viewport)?
 I tried using a masking region in the corner I want covered up, but the masking region shows up in both detail plans, therefore covering up stuff that I want to be visible in one of the plans.
Thanks
Mike
Thu, Aug 30, 2007 at 10:27:13 AM | Step matchline with crop region?
broncos4life
3.5 Stars: 11 Votes
Masking region is the only way I know of.  Since its covering up the plan in the other you could create a filter or use hide element on the masking region. When you dont want it to show.  As for a non quadrilateral crop region I have not see a way to do this.  Not even a scope box would work.
Thu, Aug 30, 2007 at 11:54:28 AM | Step matchline with crop region?
laurabh
A filter wouldn't work, since visibility/graphics overrides are shared between parents and dependent views.  Hide element in view should work.
Thu, Aug 30, 2007 at 12:54:32 PM | Step matchline with crop region?
broncos4life
3.5 Stars: 11 Votes
The issue with using hide element is that if you are working with dependent views you are not able to change the size (using the toggels) of the masking region after you have hid it in one of the views. Are you using dependent views, duplicated views, or scope boxes?
Edited on: Thu, Aug 30, 2007 at 12:55:18 PM
Wed, Sep 5, 2007 at 5:05:22 PM | Step matchline with crop region?
MYoung
MYoung Avatar
I have an overall plan with dependent views.  Hiding the masking region works great!  Thanks everyone.  Its quite easy to adjust the masking region afterwards, even though you can't stretch it using the grips.
Is it crop region or something else? Splitting up a drawing correctly matchline
Tue, Oct 10, 2006 at 2:50:59 PM
callouts and crop regions
Thu, Oct 29, 2009 at 8:31:28 AM
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:07 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:29 PM
crop region - elevations
Fri, Oct 23, 2009 at 12:43:33 PM
Page generation time: 1.1751
