Forums >> Revit Building >> Technical Support >> Can't see the roof/sidewalk
Wed, Aug 29, 2007 at 2:37:18 AM | Can't see the roof/sidewalk
MazterMind3212333
3.5 Stars: 7 Votes
Good day. I've created a complex slab that follows my topography based from eldados' tutorial on 'complex slabs and paths'. The sidewalk is a modified roof placed on a mass surface, based from the tutorial, but I can't see it on the ground floor plan and elevation views although the reference level is 'ground floor plan'. It was only visible on the 'Site' and '3d' modes. I've already checked all the model categories in the visibility overrides, verified crop regions, view ranges and still I can't see it. Is there a way for me to view the roof/sidewalk I created on the ground floor plan and elevation views? Or are objects in this category really 'invisible' on plan and elevation views? Thank you in advance.
Wed, Aug 29, 2007 at 4:20:59 PM | Can't see the roof/sidewalk
GVS02
GVS02 Avatar
I can only think to make sure the show mass button is pushed, but if you have mass turned on in you visibility properties, I don't think that should matter. If you are in Revit 2008 click your reveal hidden elements button and make sure you didn't accidentally turn it off. That's all I can think of man, sorry I couldn't be of more help.
Sat, Sep 1, 2007 at 1:17:14 PM | Can't see the roof/sidewalk
MazterMind3212333
3.5 Stars: 7 Votes
Thanks for the reply anyways
sidewalk split topo suface issues
Fri, Oct 7, 2005 at 5:11:42 PM
RAC 2009 Void on Roof
Wed, Jul 2, 2008 at 6:25:44 AM
topographical sidewalk
Tue, Nov 8, 2005 at 4:36:12 AM
ramps with multi slopes
Thu, Apr 23, 2009 at 12:30:57 PM
Elevated sidewalk
Fri, Sep 2, 2005 at 11:03:15 AM
Page generation time: 4.6613
