Forums >> General Discussion >> Revit Project Management >> Work From Home With Revit
Wed, Aug 29, 2007 at 2:09:11 AM | Work From Home With Revit
vector23
vector23 Avatar
2 Stars: 16 Votes
does anyone have an understanding of employment opportunities with Revit?
are Revit drafters being employed from remote locations?
are any Revit drafters working from home?
do any architectural firms collaborate online with Revit drafters?
are any Revit drafters working away from the office using worksets?
a lot of people have strong feelings about wanting to be a team member
working together in an office.. i'm looking for unbiased answers please..
Wed, Aug 29, 2007 at 1:32:29 PM | Work From Home With Revit
broncos4life
3.5 Stars: 11 Votes
Revit drafters can be employed from remote locations depending on file set up.   I am currently doing alot of drafting myself from home as well through a VPN and Remote Desktop.  There are a few architectural firsm that collaborate with others through FTP sites and also by comunication through fourms such as this one.  As for worksets, you need to have a good development of worksets to be working away from the office, through remote desktop or by checking out worksets.  You dont have to really work in office, but it is still much easier to colaborate in a group all sitting in proximity of eachother than a group spread across the world.  It is possible though to work in different locations with Revit.
Wed, Sep 19, 2007 at 12:54:25 PM | Work From Home With Revit
notagain
notagain Avatar
4 Stars: 1 Votes
well is anyone here working with remote a group or worksets....I am curious to see how many of us here are...since this seems to be one thing they say revit can do..
I really want this to work...some good things some bad
Wed, Nov 28, 2007 at 7:23:52 AM | Work From Home With Revit
cwsharp
1 Stars: 1 Votes
No, it is not a good option. The attention that you have to give to coordination... or the preplanning that you have to do to make checking out worksets a productive idea, are prohibitive to productivity.
I would absolutely not recommend it.
Wed, Nov 28, 2007 at 5:41:17 PM | Work From Home With Revit
vector23
vector23 Avatar
2 Stars: 16 Votes
wouldn't it be ideal to get all thedisciplines together in one office buildingeach morning to work on a project? (trueBIM collaboration).. owner-architect-contractor-structural engineer-mechanical engineer-electrical engineer-plumbing engineer-landscape-lighting-acoustics-thermal-fluid dynamics-fabracationanaylist-environmental specialist-cost anaylist-design assistants-document creators etc etc..but since most cities don't even have a railsystem to get the people there and traffic isthe worst in history- maybe we could erectan army style barracks behind the office tohouse everyone and their families.. or maybewe should just look at the internet.. you think?
Wed, Feb 20, 2008 at 9:20:39 PM | Work From Home With Revit
JHAS
my office hires Revit drafters to support our Residential project needs on a porject by project basis.  You need to know the software to be used.  If anyone wants to work from home on these Residential projects, drop my office an e-mail.
www.jhasinc.com
 James
Wed, Mar 12, 2008 at 6:13:45 AM | Work From Home With Revit
dlmerdian
Sometimes businesses purchase student licenses and allow you to download Revit at home .. ask your company if they purchased student licenses and if they did, they will give you information to download it at http://students.autodesk.com/
Wed, Mar 12, 2008 at 3:16:42 PM | Work From Home With Revit
hisdirt
5 Stars: 5 Votes
This is a really good discussion point!
I also balance working on Revit at home with heading into clients offices to work on their projects, there is so much potential with both.
Regarding Worksets, there certainly is a great oppertunity to enable remote workstations by having users check out worsets then roaming to wherever, alothough different stages of the project suit this better than others. I work alot on conceptual renderings, setting up views and sheets for clients projects. This would suit worksets well as renders can be set up, tested and tweaked, then saved to central before being rendered. Same would go for setting up veiws, cutaways, and sheets.
The crunch comes when people need to colaborate on parts of projects, detailing and such. For this I doubt there is anything better than having everyone working in the same office.
Cant wait to see what others think, as remote working is such an attractive lifestyle!
 My two cents
Fri, Sep 12, 2008 at 3:50:36 PM | Work From Home With Revit
johnphilips
Hi to all members of Reitcity,
Even I am also looking for the sam solution which you are looking vector23. Can any one solve this problem.
John Philips
 Business Opportunities
Sat, Sep 13, 2008 at 9:39:38 AM | Work From Home With Revit
There are several discussions of this here on the RevitCITY site and AUGI.  I suggest you check those out.  There are also items in your help that will lead you to some possible solutions.  Because REVIT is multi-user, there doesn't seem to be a perfect way to do this.  Read up on checking out worksets "at risk".
Fri, May 14, 2010 at 8:20:11 PM | Work From Home With Revit
bpwg55
We've installed one of our revit seats (license) on a server. Then it's "available" via the internet (serious password) with remote desktop (terminal services). With reasonable pipes (internet) at each end, it make for a pretty good revit station.
The remote user, is only getting screen refresh. The "big" data, is only moving from our "big" file server to the workstation/server, about 5 feet.
So far it's working pretty well. We're actually using worksets also, so we have 3 users in house, and one remote on one workset/file.
If you use two remote users, then there is an issue as you don't have different user names, which is going to create issues with the worksets. It's also running up against liscense issues as you now have two users using one liscense. Of course if you use Lmtools and check out licenses, then you are probably good there too.
We were doing the vpn thing, but moving the big files (90meg) was just too slow, and we finding keeping the big file in the office and just remoting the desktop is working much better.
We're looking at terminal services - gateway, where the gateway can direct the user to a specific server, and have multiple servers serving the various outside users, instead of just having one open port and one server.
Our "server" is actually a VmWare server, running server 2008. With a lot of ram, it's pretty easy to run several instances of these. Of course your "pipe" is going to get saturated pretty soon, so you got to watch that bottleneck.
The new cpu (55xx series) with three parallel memory channels, are so fast, it start making all this remote stuff very usefull, where just awhile back, it's was just too slow.
I'd be interested in how others are setting up remote users. We looked at Peerlock, with a server at each end replicating all the time and file locking when a file was open, but it's about $3,000 each end for software, then servers and it gets pretty expensive quickly.
We've also got multiple "pipes" with different ip addresses, and are trying out 2 different addresses, pointing to two vm server, so each user has their own environment.
Working @ home
Thu, Dec 23, 2010 at 7:39:17 PM
CENTRAL-LOCAL FILES, WORK FROM HOME SETUP
Mon, Feb 7, 2022 at 3:43:01 PM
making worksets editable at home
Mon, Jun 6, 2011 at 11:29:35 AM
Revit liscense
Thu, Jan 19, 2006 at 5:09:13 PM
goining from 8.1 to 8.0
Thu, Jan 5, 2006 at 12:02:59 PM
Page generation time: 3.5859
