11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Alpha Channel?
I use revit 2008. Experience from other rendering programs tells me that i have to export the image as a tiff file in order to select my model in photoshop (alpha channel). I've looked in forums and people say that it can be done with revit as well, I don't know what I'm doing wrong. Once the image is fully rendered, I click on the 'Export Image' button in the rendering pulldown. My file type options are JPG, JPEG, BMP, and PNG. Do one of these file types do alpha channel or is there a way to export my image as a tiff? Thanks for the help.
the latest Revit build (Build Number 20070810_1700) allows you to export tiff format HTH
Thanks coreed. I should've mentioned I'm new to Revit. Where can i find the revit build #? Is it just a plugin for the Revit version i have now? Thanks
Export to dwf alpha channel |
Mon, Feb 13, 2012 at 4:08:16 AM
Revit 2008 & exporting alpha chennels |
Wed, Sep 5, 2007 at 2:28:18 PM
Rendering with no sky. |
Sat, Mar 21, 2009 at 7:57:10 AM
Can I use images with alpha channel? |
Sun, May 18, 2008 at 6:12:33 AM
Revit 2010 to 3ds Max Design 2010 |
Mon, Aug 10, 2009 at 4:46:18 PM
