18 Users Online (16 Members):
Forums >> General Discussion >> Wishlist >> Square Ended Lines
REVIT currently draws lines as if they were created using a round nibed pen. Most of the time, this is not a problem because, for typical drawings, we don't use pens over a #2. However, when you use a larger pen on title blocks or visual "boxes", you get this "crayon" end that really looks bad at both line ends and corners. This morning, I ran into a bigger problem. When you use a dashed line or dash dot with a large pen, the space between the segments gets filled by the radius of the pen. In other words - the distance between the line segments is fixed and measured from the center of the pen - not the clear distance between the segments. Our heavy lines look fine in a small scaled view but when drawn 1 to 1 they become a continuous blob line. Not good! AutoCAD lines are square ended and REVIT's lines should be square too. (BTW, the old split nibed pens were basically square - the round ended line look came about with the technical pens. )
46 Posts No Rating |
WWHub,
Did you know if Revit provides square ended dashes now...Revit 2012?
thanks
They are still round.
how to dreate a double gable ended roof on a square structure???? [ 1 2 ] |
Fri, Mar 13, 2009 at 7:42:49 PM
25
Square Lines and Corners in Revit 2008 |
Thu, Oct 4, 2007 at 6:58:21 AM
Rentable Square Feet Calculation |
Wed, Jan 28, 2015 at 9:29:10 AM
Looking for quick easy square footage calculator |
Mon, May 19, 2014 at 10:49:34 AM
Square Yards calculations |
Mon, Mar 19, 2012 at 3:00:43 PM
