Forums >> Revit Building >> Technical Support >> 8 side pyramid lay-in ceiling. Help.
Mon, Aug 27, 2007 at 4:59:05 PM | 8 side pyramid lay-in ceiling. Help.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I have an octagon shaped space and would like to have a sloped (2x2 lay-in) ceiling that starts at 11-4 at the perimeter and slopes up to 17-4 at the center.  I have assumed that what I need to do is to create a sloped triangle shaped ceiling panel once and then mirror it around the room.  No problem creating that exact sloped ceiling panel.  I cannot seem to get the grid aligned properly to it.  I have created it on a flat plane.  Aligned all of the grids with the base and centerline of the triange, edited the ceiling shape by adding a slope arrow to it, finished, and the grid is now offset from the centerline and running off at an angle, not aligned with any of the edges.  Once it is sloped, you can't "align" any of the grids.
 Any suggestions other than go to a flat ceiling and forget about it?
Tue, Aug 28, 2007 at 7:19:11 AM | Anyone?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Anyone?
Tue, Aug 28, 2007 at 10:50:55 AM | 8 side pyramid lay-in ceiling. Help.
Do it as a sweep around either the upper flat area or the lower perimeter.
Tue, Aug 28, 2007 at 2:07:44 PM | How does that fix the mis-aligned ceiling grid?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
The sloped ceiling un-aligning the grid is my problem.  I can build the stupid octogan pyramid shape in a dozen different ways.  It's getting the grid to "behave" on the surface of the sloped ceiling where I need help.
Advanced Revit Family issue. Please help Revit gurus out there...
Sat, Aug 13, 2011 at 11:19:46 AM
spot elevations - lay-in ceiling
Thu, Oct 27, 2005 at 2:49:21 PM
Square pyramid
Mon, Dec 19, 2005 at 12:16:36 PM
Splitting a ceiling
Fri, Nov 11, 2011 at 12:34:50 PM
Why are my light fixtures on wrong side of the ceiling?
Fri, Dec 13, 2013 at 9:38:09 AM
Page generation time: 0.2028
