16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> DRAWING ANGLED WALLS
9 Posts No Rating |
Was just wondering if anyone knew how to draw an angled wall in Revit 9. By angled I mean straight in plane but the bottom and top of the wall are offset from each other. The top of the wall sticks out over the bottom. How do you get a wall to do this without having to create a mass instead?
If you mean the wall lies in a vertical pane then click on the wall and choose edit profile from the options bar.... Yo can create a parallelgram or even a circular wal. If not that, then please clarify.
Use massing.
9 Posts No Rating |
Thanks guys but I needed to draw glass curtain wall on an angle, and be able to put a curtain grid on it to create mullions quickly. I did make a mass out of glass and it worked but I was unable to apply a grid. Just wondering if there was a quicker way of doing it thats all.
watch this free cadclip from CADClips (DGCAD). you can do the same with straight line also. it should solve your problem http://www.cadclips.com/downloads/CADCLIP-CURVED-CURTAIN-SYSTEM.wmv HTH
9 Posts No Rating |
Thankyou so much for that... problem solved!
2 Posts No Rating |
I am rather new to Revit and need some instructions on how to use the mass and face option for bulding walls. I'm trying to build a curved angled wall, but I just can't figure out how to go about it.
2 Posts No Rating |
Making Angled or canted walls |
Tue, Jun 3, 2008 at 2:10:07 PM
Angled Walls in Revit |
Mon, Jan 12, 2015 at 8:48:26 AM
Curved Angled Glass Walls |
Thu, Jan 20, 2011 at 3:01:49 PM
Revit 2011-putting openings in angled walls. |
Sat, Sep 10, 2011 at 5:45:27 AM
angled walls |
Thu, Jun 25, 2009 at 11:08:21 AM
