Forums >> Revit Building >> Technical Support >> Sink not visable when using counter top family
Sat, Aug 25, 2007 at 5:20:40 PM | Sink not visable when using counter top family
boydj
I have used  the following families to create a domestic bathroom vanity"
  • two door vanity cabinet
  • vanity counter top (2 sink holes)
  • sink vanity round 19"
Problem:
I can not get the sink to show up in plan view.  In 3D and in section it is right where it needs to be - in the counter top hole.  For some reason it is only when i offset the sink from the floor high enough to break the plane of the counter top backsplash does the sink finally show up in plan.   I know I am just not doing something I should be.  I am almost sure it has something to do with how the counter top was made.  There is a direct relationship between the height of the backsplash and the height of the sink
Thanks for any help
Mon, Aug 27, 2007 at 10:11:13 AM | Sink not visable when using counter top family
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
check your overrides and view depth. if that doesnt work try a different sink. and plane host it on the vanity
http://familyjewels.typepad.com/
counter top model
Mon, Feb 28, 2011 at 2:11:16 PM
Counter Top w Sink in Revit 2013
Mon, Mar 11, 2013 at 5:36:29 PM
Vanity Sink and Counter Top and Toilet Paper Holder Visibility Issues
Mon, Mar 19, 2007 at 7:05:20 PM
Cutting countertop for sink
Tue, Apr 15, 2014 at 5:21:32 PM
Getting away from have Bench Tops/Counter Tops with Parametric holes for Sinks
Wed, Aug 8, 2012 at 6:51:22 PM
Page generation time: 0.7890
